Looking For More Info About Emergency Tube Tent Shelters? You’ve come to the right place!
First, let me ask you a question: What’s the best way to survive the elements? The right gear.
And of all the things you need for survival, a temporary shelter is among the most important.
And please, avoid packing mega tents—they’re fine for camping trips or even backpacking. But when you are bugging out, they’re too heavy and take up too much space, that’s for sure.
Instead, you need a practical solution that’s easy to carry and sets up fast. The best solution? A Tube Tent.
Skilled survival is here to equip you with survival knowledge. AND help you find the best gear for your adventures and emergencies.
That’s why we’re big fans of getting a tube tent.
They’re a vital piece of equipment for all kinds of outdoor emergencies.
What’s A Tube Tent?
It’s pretty much in the name. A tube tent is a long, narrow emergency shelter. It’s made to fit 1 – 2 people and will get you off the bare ground and provide cover overnight.
When you are bugging out and must survive the elements, you need a place to sleep. A tube tent shelter comes packaged tightly and easily fits in your survival backpack.
Listen. When you are escaping a crisis or invasion, you need to travel light. Even for your camping and hunting trips, you have enough gear to worry about without adding a bulky tent to the mix.
Often, it’s not worth spending time putting up a bunch of tents, especially in survival mode. You need a fast setup for bedding down because survival is NOT glamping!
Your emergency tube tent takes less than 5 minutes to set up and is pretty much idiot-proof.
Here’s how you set it up:
There are instructions in the package, but it’s not a 1000-piece Lego set. Getting it up doesn’t require an engineering degree. It only has two pieces, a tube of tent material and some cord.
- Layout the tent flat on the ground.
- Feed the cord through the tub. Then tie tightly about 3 feet off the ground against any two vertical structures. For example, two trees or fence posts or whatever is around. You can even tie one end to your vehicle.
- Spread out the corners and weigh or anchor them down.
- Close off one end of the tent to keep out the weather.
- Lay your sleeping bag out, and you are good to go.
If you’ve packed a thermal blanket to lay underneath, that’s great, but really, comfort might have to take a back seat. A tube tent is a quick, practical survival solution in a pinch.
Why Should You Get A Tube Tent
If you are a prepper or survivalist, it’s a no-brainer. It’s like asking a sailor if they should get a life jacket.
An emergency tube tent is probably the most basic of tents, but that is what’s so awesome about them. You want a tent that is lightweight and easy to carry. You also want a quick setup and breakdown for fast travel.
So, who needs one?
Probably not Great Grandma. But most everyone else who likes spending time in the wilderness will need one. These folks include outdoor enthusiasts, preppers, campers, and hunters.
The bottom line is if you’re on the move and require a fast, overnight setup for sleep, then a tube tent is right for you.
Another reason you should get a tube tent is for practicing your bushcraft. Honing your survival skills is essential before a catastrophe happens. You want a quick, practical setup to keep you and yours out of the elements and secure overnight.
So, should you get a tube tent? You should get several tube tents and put them in your bags and backpacks as well as in the trunk of the car.
Emergency Tube Tent Uses
When you and your family are all tucked in safe at home, you have beds to rely on for sleeping. But if there is a compelling reason to get out of dodge fast, you better have a tube tent for every family member.
Here are a few activities that require an emergency shelter tube tent.
- Hunting
- Camping
- Fishing
- Hiking
- Backpacking
- Bug-out situation
- Emergency survival
- Remote accident
- Prepping
Any situation where you might need to spend the night in the elements is why you carry a tube tent. It’s survival gear you may not need every day but it’s essential when necessary.
And it doesn’t stop there. Because these tube tents are reasonably cheap, you can use them as a poncho or windbreaker for weather events.
It can be a great emergency blanket too.
You can fashion them into a bag to carry gear, and most are bright orange so that you can use them for signaling purposes.
Best Tube Tent Features To Look For
Not all tube tents are created equal and have the correct setup. Look for these features:
- Rugged polyethylene construction
- Included paracord or similar line
- Tent pegs
- Fire retardant
- Waterproof
- Lightweight and tightly packaged
- Simple setup
You can get your emergency tube tent in different colors. But the best are either bright orange, so it’s easily seen in an emergency. OR a camo tube tent for hunting and threat evasion.
Remember, this is an overnight shelter designed for survival and NOT for comfort.
Pros And Cons Of An Emergency Tube Tent
With everything in life, there is a balance. You must take the good with the bad so let’s go over the pros and cons of having an emergency tube tent.
PROS
Compact & Lightweight
Your tube tent is easy to stow in any of your go bags and backpacks. It will not add any noticeable weight to your carry at all.
Quick Setup
There are no parts to assemble. It’s as basic as possible for a fast setup, so you can get under cover quickly.
Cheap
These tube tents are very affordable. That way, you can buy them in multiples and have them ready for anyone who needs them.
Multi-Purpose
The primary use is for temporary shelter overnight. But you can also fashion one into a poncho or a carry bag. You can even use it for emergency signaling.
CONS
Not Long Lasting
A tube tent is an inexpensive item for emergencies. It will not stand up to years of use.
Not All Weather-Proof
Because of the design, they are open at both ends. You can close one end up but need fresh air from the other. Water may get in during storms.
Small Size
You can fit two people, but it is better for one person and their gear. This means if you are traveling with a family, you will need multiple tube tents.
Ultimately, you are not buying a tube tent shelter for high-end camping. It is a tool in your emergency survival kit and is there to provide overnight protection when you need it.
7 Best Tube Tents You Can Buy Online
Skilled survival has scoured the web to find you the best tube tents on the market today. There is a good selection of emergency tube tents. And we only want the best for you, so check out our list of the seven best tube tents.
1. Survival Frog – Ready Shelter Tube Tent 2.0
We are starting with the Ready Shelter Tube from Survival Frog. They are a top-quality company with great gear, and this tube tent is no different.
Their waterproof emergency tube tent is a lifesaver in emergencies. It easily fits two people and will protect them from harsh weather, including rain, snow, and even the sun. And the best part? It can fit into your pocket!
It only weighs 7 ounces, and you can set it up in a matter of minutes. All you must do is slide the included cord through the tent and anchor it to 2 points, and you are good to go.
The tent is 7’x5′ and has an orange waterproof side. And a HeatEcho thermal side that reflects 90% of your body heat back to you. That will help keep you warm at night. If it’s a hot summer day, you can turn it around to keep the heat off your sleeping setup.
The nylon rope is 16′, so you can find some trees to tie it up easily, and the tent is tear and puncture-resistant too. You can reuse this tent many times, and it can be folded back up and stowed in the little orange bag it came in.
We recommend this emergency tube tent for your next overnight in the wilderness.
2. Bearhard – 2 Person Tube Tent Survival Shelter
Bearhard has a great offering in their Tracker Series with this emergency tube tent. They want to protect you in extreme weather conditions like:
- Hurricanes
- Tornadoes floods
- And wildfires evasion
And the 100% waterproof tube tent works as an emergency shelter, bivy sack, and thermal blanket in one.
This makes this tube tent ideal for camping, hiking, and kayaking. This emergency shelter tube tent is made from Nasa technology material called Mylar. It’s a reflective aluminum coating that is 0.45mm thick. It gives you that critical 90% heat retention and is tear-resistant and waterproof too.
It comes with a 23′ paracord, metal carabiner, and four plastic stakes. Plus, it comes with a high decibel emergency whistle and nylon drawstring bag. They think of everything and include it in one multifunctional kit.
It folds down to 8″ x3″ x3″ and weighs only 0.8 lbs., so you can carry it easily in your backpack or vehicle. It also comes in 4 colors: Green, Brown, Orange, and Camo.
Just like all their products, Bearhard has a lifetime warranty. And 24/7 customer service so you have peace of mind you are getting a top-quality product.
3. Go Time Gear – Life Tent Emergency Survival Shelter
Go Time Gear has an impressive tube tent on the market. It’s great for survival, emergency, and overnight adventures.
The tent is made of extra-thick polyethylene. And is puncture and tear-resistant with 28um heavy-duty mylar material. This keeps you protected from wind, rain, and snow. And it weighs under 9 ounces with a size of 5 1/4″ x 3 1/4″ when in its pouch.
You can fit two people inside, and it will keep you warm with a heat reflective interior. Set up is easy too. It comes with a 20′ 550lb paracord that you run through the 8’x5′ tent and attaches to anchor points 3-4′ off the ground. They even include a 120-decibel emergency whistle that carries up to 1 mile away.
Go Time Gear has world-class customer service, so they will take care of you if you have any issues with your tube tent. Add this tube tent shelter to your survival bag.
4. SAINUOD – Emergency Survival Tube Tent
Here we have a camping survival package that will take care of the whole family.
Sainuod provides quality with their waterproof and windproof emergency tube tents. You get two tents and four sleeping bags that are all ultra-light and have thermal reflective material to keep you warm.
The two tents’ setup was easy with paracord ropes and rope clips for extra wind protection. You’re protected from rain, wind, and snow with the Mylar material construction. And they are reflective, bright orange so a rescue team can find you during an emergency.
This pack is individually stowed in their own bags. And fit easily in the trunk of the car or everyone’s survival bag or backpack.
5. Don’t Die In The Woods – World’s Toughest Ultralight Survival Tent
This is a mighty claim to make, but Don’t Die In The Woods can back it up. They guarantee their ultralight survival tent is the toughest you’ll find anywhere.
They use heat flex mylar that’s more flexible and more robust than the competition. And it will withstand the harshest conditions Mother Nature can throw at it.
They also tested and designed their tube tent using the highest-quality materials. So, hikers, hunters, and outdoor adventurers will be taken care of, that’s for sure.
Included is a heavy-duty 425 lb. paracord, so it will keep your emergency shelter tube tent secure. Just run the 20′ cord through the tent and attach it on either side. Then anchor your tent corners with something heavy like rocks or some of your gear and roll out your sleeping bag for a warm night’s sleep.
Just keep this tent away from open flames as it is not fireproof.
The kit includes the tube tent, paracord, and a nylon storage sack, and it weighs in at just 8.5 oz. It’s a great, reusable emergency tube tent for all outdoor enthusiasts. So, keep one in your car, survival bag, earthquake kit, and go-bags.
6. Sharp Survival – Emergency Survival Shelter Tent
This emergency tube tent is from Sharp Survival and will provide warmth in any weather. The Nasa mylar thermal material is designed to send back your own body heat and keep you toasty all night long.
Just put this kit in your backpack or prepper kits. That way, it’s ready for your outdoor activities and never caught off guard.
Set up is a snap with this compact, lightweight tube tent. Just run your rope through the tent at around 3 feet off the ground and spread out the bottom. Then crawl in with your sleeping bag and get some rest with this 8’x5′ Tube Tent Shelter.
Sharp survival offers you peace of mind. Now you’ll know you’re protected in case of an emergency while out in the elements.
7. Swiss Safe – Emergency Two-Sided Survival Shelter Tent
Are you looking for options with your tube tent? Do you want to blend in and stand out?
Swiss Safe can answer the call with their 2-sided tent. If you are hunting or hiding, use the woodland army green side. Flip it over for a high-visibility orange color for more visibility and rescue.
It is an all-weather, all-year emergency tube tent. As part of your survival kit and outdoor activities, you want to cover yourself overnight in the elements. The tent fits two people and is very durable and tear-proof.
Ideal for your minimalistic camping and hiking trips. This tube tent will provide wind, water, snow, and moisture cover.
This kit comes with everything you need to set up and maintain your shelter fast. And it’s all packing one bag!
It includes:
- 4’x8′ Dual-Color Tube Tent
- 20 ft 450-lb 8-Core Military-Grade Paracord
- 4 – 6″ Heavy Duty Spike Stakes
- Several – 12″ Tiedown Strings
- 4 – 5″ Zip Ties
Add it comes with a 100% money-back guarantee. So, you’ve got yourself no more excuses but to buy 5 or 6 for your emergency preparedness.
Tube Tent Wrap Up
Do you feel like you’ve gained knowledge about tube tents today? That is our ultimate goal here at Skilled Survival.
Now you can confidently go out and stock up on the best emergency tube tents for your preps.
“Just In Case” Jack
The post 7 Best Tube Tents For Survival, Preparedness, Evasion and Rescue appeared first on Skilled Survival.
