Best Headlamps For Camping, Hunting, Survival, Etc.
If You’re Searching For The Best Headlamp, You’re In The Right Place
best headlamp
Because it’s easy to get overwhelmed with thousands of options on the market today.
Sure, some are great, but most are complete rubbish!
This article covers all the features to help find the best headlamp for YOU.
We also look at the best ones per activity, for example:
  • From Camping to Running
  • Hiking to Home Maintenance
  • Backpacking to Climbing
  • Boating to Fishing…
  • Etc.
That’s why today, I’m going to use my extensive Engineering, Offical Gear Design No-Bounce Rechargeable HeadLamp
  • Max Lumens: 200
  • Max Beam Distance: 50m
  • Weight: 1.8 oz.
  • Battery Type: Rechargeable
  • Run Time (High / Low): 3/40 hours
  • IP Weather Resistance Rating: IPX4
The BioLite HeadLamp 220 is, hands down, the most comfortable running headlamp I’ve tried.
The lightweight and broad lamp base makes it very stable on your head.
So you’ll have almost NO bounce while running.
I could wear it with a lighter tension in the headband, which was VERY comfortable on long, hot runs.
The USB rechargeable battery lasts long enough for a good run and has a great life on the low setting (up to 40 hours).
The high-power LED is serviceable, but at only 200 lumens, it can sometimes leave you wishing for more power.
The lack of a rear LED is also unfortunate for neighborhood runs where visibility is vital.
It also has a small control button, so manipulating it with gloves is challenging.
PROS
  • Extremely comfortable
  • Lightweight
  • Inexpensive
CONS
  • A little underpowered
  • No rear safety LED
  • Tiny control button
<a class="lasso-button-1" target="_blank" href="https://www.skilledsurvival.com/biolite-headlamp-200-no-bounce-rechargeable-headlamp/" data-lasso-box-trackable="true" data-lasso-id="19041" data-lasso-name="BioLite 200
